93 pace arrow
Mackenu
30 amp plug doesn't run ac but gen.does any good ideas?
93 pace arrow
Cummins with Allison 6 sp.
5 REPLIES 5
Mackenu
Thanks for the suggestion I am still troubleshooting
93 pace arrow
Mackenu
Im not sure but would there be some kind of switch I cannot find to switch it over to shore power?
Thanks for the info
I looked everywhere for a switch and didn't find one
Also I don't know much about this mh just bought
93 pace arrow
Ava
I have a switch in one of the upper cabinets that controls one or the other a/c units to operate when powered by 30 amp plug
enblethen
If you have two ac units, only one will run off the 30 amp shorepower. The other is not connected.to shore power, t is connect directly to genset.
Only possibility other then that is a cycler unit that allows one ac to run then the other. It could be an Intellitec unit.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MrWizard
Moderator
Moderator
there is possibly a switch someplace to choose how it will be powered
also some 30amp RV's with (2) A/C units, only one is connected to shore power
30 amp = 3600watts, 6000w generator has more power, than 30a shore power
by the way
don't name every topic/question 93 pace arrow
members won't know which one is which
pick subject titles appropriate to the problem
I can explain it to you.
1997 F53 Bounder 36s
