โJun-21-2013 05:12 PM
โJun-23-2013 06:53 AM
โJun-22-2013 09:56 PM
โJun-22-2013 09:06 PM
โJun-22-2013 08:16 PM
โJun-22-2013 08:08 PM
psmoore wrote:
How would i check the temp that both units are putting out?
โJun-22-2013 07:43 PM
dougrainer wrote:psmoore wrote:
No it will not run both on generator very well. We only run one. We have 30 amp service. Now that i think of it, when we run both the amps show 26 on my power supply channel. Will try today and see what happens.
IF your Winne came from the factory with 2 AC units and the Gen(APU) is at least a 5.0kw or higher, you CAN run 2 AC units with no problem. Explain what you mean by "it will not run Both very well"? That statement does not make sense. You have a 30 amp RV with a EMS system.
EMS---ENERGY MANAGEMENT SYSTEM.
That means you have 2 AC units and Winne installed an EMS system. The EMS automatically manages your 120 appliance loads when connected to 30 amp shore power and will turn off(shed) power to non essential appliances if you approach the 30 amp total threshold. The rear AC is usually the first appliance shed. But, On APU you CAN run 2 AC units, if your BOTH AC units were installed by Winne. IF the EMS shows a rear AC it was installed by Winne. The APU has 2 -120 breakers and the 2nd breaker (20 amp) on the APU is dedicated to the rear AC only. IF the 2 AC units do not run on APU you have a operational problem with the APU. Doug
โJun-22-2013 01:30 PM
โJun-22-2013 12:50 PM
โJun-22-2013 05:29 AM
โJun-22-2013 04:22 AM
โJun-22-2013 02:07 AM
โJun-21-2013 07:31 PM
โJun-21-2013 06:54 PM
โJun-21-2013 06:50 PM
