โJul-17-2023 12:48 PM
โAug-23-2023 10:08 AM
wpatters1229 wrote:
I have two meters one being a fluke. I also have a degree in electronics. But was not sure of how the RV deals with this A/C problem. I did figure it out and all is well.
โAug-20-2023 02:32 PM
โAug-20-2023 02:26 PM
โJul-25-2023 11:23 AM
VA-Apraisr wrote:
I think that electrical cord may well have been your problem, but doubtful on cutting the a/c cover opening...
โJul-23-2023 07:47 PM
โJul-19-2023 03:01 PM
โJul-18-2023 09:48 PM
โJul-18-2023 05:39 PM
wpatters1229 wrote:
OK, all electronic theories are out the window. Yesterday I had the shroud off the A/C and it was very hot in our area. I think it exposed the compressor and coils to more heat than it could handle. Today I put everything back and also cut away some of the grills in front of the exhaust radiator fins and coils. I read that it blocks the airflow and can reduce the cooling effect. I fired the unit up today and it has been running for over an hour. It is a bit cooler today but still plenty hot. 83 today and yesterday 99. I am not sure if there is a safety cutoff on this Coleman A/C but it would not surprise me. Thanks for all your help.
โJul-18-2023 02:35 PM
โJul-18-2023 01:40 PM
wpatters1229 wrote:
One other thing. I have an extension cord going to a 20 amp wall socket that hooks up to my 30 amp cord using an adapter. It has never been a problem.
โJul-18-2023 12:26 PM
โJul-18-2023 09:38 AM
โJul-18-2023 09:35 AM
time2roll wrote:
Really need a volt reading in the RV and a clamp-on ammeter to do some actual diagnostics.
Although at least verify the fridge and water are off or set to propane only. If the battery was low that converter will also draw significant power for 30 to 60 minutes.
โJul-18-2023 09:30 AM
