AC electrical problems
balfre1946
We are in a 2010 Fleetwood Fiesta 34B and from the beginning we have had AC problems. What happens is both the front and back units will click off then after a few seconds click on, eventually the back unit will stay off. This happens whether we are on AC or fan so it must be an electrical problem. When they both work, this place is an icebox. This mostly happens in the day, not so much in the evenings. We have had technicians over and no one seems to know why..inverter??
If you are in the Charleston SC area and can fix it, you can name your price as we are full timers.
12 REPLIES 12
enblethen
Is this what you have in black?
Thermostat
Here is manual stating where fuse is located.
RV comfort ZC manual
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
balfre1946
it just says rv.comfort. zc
enblethen
Can you post make and model of the thermostat?
Bud
USAF Retired
Pace Arrow
balfre1946
THe thermostat is a very simple black box...no fuse inside
enblethen
Have you tried resetting the thermostat?
Open thermostat to expose fuse on circuit board, remove fuse and wait 15-20 seconds, re-install thermostat and have the system reboot itself. This could take 15-20 minutes.
Bud
USAF Retired
Pace Arrow
balfre1946
Only the back AC kicks off, can come back on or it then stays off. I go outside, unpluug, count to 30 slowly, plug back in and that seems to resolve things, at least for a while. This tends to happen more when it is very hot and sunny, less so or not at all on rainy, cloudy or cooler days. Any thoughts? Our termostat dors not look like htat at all, very simple one.
wa8yxm
Two posibilities, If you have a load shedding energery manager like the one photoed above.. Suspect #1
My story (I do not have one of those) Sometimes front A/C worked, sometimes rear sometimes both..... Finally got to trouble shooting.
First stop: The power distribution (Breaker) box (Also the last stop)
Several screws which hold the wires in the clamps were loose, like over two turns loose on one of them... Yup, that was the problem..
I keep saying many RVers have a few screws loose.. In my rig those take a #2 Square Bit.
budawne
Well your not alone. We are having same type of issue.My name is Bud and we recently went from a 2007 Thor Mandalay M40g with yes some problems traded it for a 2008 Mandalay M40hall was well for the first trip had the same issue but we had a bad transfer switch that was under a recall and Thor took care of it no charge thanks T.M.C. All was good till the second trip when it happened again. We keep it plugged in at home to a 50amp service has a surge protector, when we go away I test power supply with a meter and it's good. So this time drove 2 hrs. generator on both a/c's working and very cold cycling on and off all is good July 3rd. it's 95 and we live in So Fl. plugged in like usual shut off gen. landing gear I call it open slides and within a 30 min. both a/c's go off at same time thermo goes blank and have apparently inverter power only as a few outlets etc. Tried generator, tested transfer switch had power through the power cord as surge protector was lit and power through it (correct power and flow no faults) I tripped reset all breakers all good. Getting ready to cancel trip as it's so hot then a/c's came back on after 3 hrs. All worked for the rest of the weekend no problem. The next weekend I set a/c's and was outside detailing coach all was fine maybe 90 out a few hours later went in to cool down no problem then as before both a/c's shut down this time I waited went in an out several times then said screw it shut every thing off, unplugged and went in house. Next day went on roof took covers off a/c's and found 2 mud dobber nests in each a/c coil about 2"x5" cleaned them out real well blew out coils with air from coach put covers back ran a/c's to check and shut off. Next weekend brought into shop they road tested, had gen.on/off shore power slides open closed run and even set to 70. They checked power cord and surge protector good check circuit panel good as them to look at P.M.S. power management as of 8/15/14 they have not been able to duplicate the problem as of yet today 8/16/14 I pick it up i'll road test it set up in yard as I do and run everything as I would be on a trip. Oh boy I get to camp out in my back yard!!! Will let you know if problem exists.
OnaQuest
Do you have an on-board generator? Will both ac units operate when you run the generator?
Does your thermostat look like this?
chuckftboy
That sounds like your EMS is doing some load shedding. That is if you have an Energy Management System? Slim possibility that the thermostat could also do that. There souldn't be amything in the line voltage that would automatically restart a load like that.What else is on when this happens?
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
enblethen
Could be a thermostat problem.
Does it have an energy management system? What unit.make and model?
Inverter should not effect the AC as most rigs do not run AC units off inverter.
Try turning breaker off for AC units. Turn off unit one and see what happens, then do the same for second.
Is the rig a 30 or 50 amp shore power?
Bud
USAF Retired
Pace Arrow
Fishinghat
My guess would be an overloaded automatic resetting circuit breaker that trips, resets, and then restores power. When it does, both A/C units are in start up mode which causes an excessive amperage drain and voltage drop resulting in the automatic shut off of one of the units.
What can you do? Not sure. It depends on where the automatic circuit breaker is at.
You could try by-passing the breaker by drawing power to your RV from two electrical posts, and devoting one post to each air conditioning unit.
Or, there are electrical devices that will correct for low voltage by increasing the output voltage to a full 120. That device would be installed between the power post and your RV, probably at the point where the power cord is plugged in to your RV.
Holiday Rambler Navigator DP, Hummer, and Honda VT1100C Shadow
