Well Carrier has a frost sensor.. And there are other possible issues.
$2,000 is at least DOUBLE the cost.
Advent Air, Which I do not recommend, has an "Adapt a kit their top unit with the kit is a direct replacement for the Carrier top unit.
Coleman .. The adapt a kit is a bit more complex and a 3rd party if you can find it but they still use the carrier control system... That said.
The problem MIGHT be the control system, not the top unit.
Carrier no longer is in the RV A/C business.
