โMay-08-2013 12:31 PM
โMay-09-2013 05:10 PM
brandonrv wrote:
Yeah I've got the adapter. Looks like the 7 pin side is right but the 4 pin side is not right. I guess I should try to wire it myself. How can I tell what the 4 pin is set up to on my Jeep? I assume I just have to match colors?
โMay-09-2013 12:51 PM
โMay-09-2013 11:48 AM
โMay-09-2013 11:38 AM
โMay-09-2013 10:09 AM
tropical36 wrote:Tropical36, you missed the part where he tried a 7 pin to 4 pin adaptor and it still didn't work. I'm thinking a good old fashion test light at the 7 pin outlet on the motorhome to figure out what each pin is for, and then working his way back to the toad. I just go the the local hardware store, buy my cord cut to length, and wire it myself. That cuts my cost in better than half of what the special made cords cost.brandonrv wrote:
I got my jeep wired so that I can plug directly into the front of it when I'm towing. Problem is they installed a 4 pole round connector in the front, but I've got a 7 pole RV connector on the RV.
Anyone know an adapter for this or do I have to go get the RV wired for 4 pole round now?
Are you saying that you have a 7 to 7 umbilical cord? If that's the case and since I like having spares, I'd just replace the four on the toad with a 7 to match. If not and don't like doing these things for yourself, COOLTECH has a 7 to 4 umbilical cord already made up.
โMay-09-2013 07:53 AM
โMay-09-2013 07:32 AM
โMay-08-2013 09:53 PM
โMay-08-2013 05:34 PM
brandonrv wrote:FIRE UP wrote:
brandonrv,
Yes Sir, they make adapters for 7 pin RV plugs to any configuration you want, 4-pin flat, 4-pin square, 4-pin round, 5-pin round, 6-pin square and more. DO NOT CHANGE THAT PLUG ON THE RV!! It's most likely wired by the factory and is well done and to national color coding and pin placement. It might be useful at a later date when you might wand to hook up a larger trailer etc.
One of the first things you must do is, make sure that the wiring/pin arrangement in your seven pin RV plug is configured so it will match up to the 4-pin round correctly. We've owned four different RVs, (2) Class Cs, and (2) Class As. All four came from the factory with 7 pin plugs. As did and does, about 99.9999% of all the pickups sold in America.
Most of your adapters can be found at Camping World, or any other well supplied RV Supplies outlets. One of the nice things to have around is an "LED", 7-pin plug checker. I just got one from a local swap meet for about $5.00 and man, is it great. You can check the out put right at that plug and see if all is good every now and then.
Scott
Thanks, scott. Maybe that's the problem with my adapter. The pins don't match up. I'll look at getting one of those 7 pin testers. Maybe I can figure out how to rewire it.
โMay-08-2013 05:32 PM
โMay-08-2013 03:20 PM
โMay-08-2013 02:50 PM
โMay-08-2013 02:25 PM
brandonrv wrote:Mandalay Parr wrote:
Can you remove the 4 pole round and wire in a 7 round?
I can't.. I'm sure I could pay someone to do that. I took my jeep to a motorhome dealer to do the wiring for me. Figured they knew what they were doing.
Got home realized it doesn't hook up. Got online can't find many adapters. Found that Hopkins one and bought it. Doesn't do the trick.
This 4 pole round is sort of a mystery.
โMay-08-2013 02:23 PM
