Air conditioning leaking
ricelake922
Hello. I have a 1996 Monaco Dynasty and when I have the air conditioning on there is water coming from the roof. Is this normal and if no what might be the problem please. Thank you in advance.
7 REPLIES 7
time2roll
msmith1199
Yes, it's normal and just fine. But just to clarify, it isn't leaking as there is no water in the AC. It is condensation that forms on the coils and then drips off into the pan and out the drain hole and normally across the roof.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
azdryheat
Condensation
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
rgatijnet1
Normally water dripping off of the roof is not considered a leak. If your AC unit is leaking in to the interior, then it is probably the AC gasket that needs to be tightened or replaced. This is not that difficult of a job to tighten or to replace the gasket but with a 1996 coach I would say it is long overdue.
dtucker3usa
ac normally will make water while cooling air removing moisture. Now where it drains depends on manufacturer. On my 96 Rexhall it runs off the roof. How I am leveled dictates which side it will run off. Some coaches have drains and will drain below the coach. Now if you have water coming into the coach that is another problem.
X2
korbe
When I see the drops coming from an exterior corner of our rig, that tells me all is working fine. ๐Ÿ™‚
ets1996
