Air Leak at or near park brake switch
wtmtnhiker
Hi all,
I noticed a noise near my parking brake switch valve that is definitely air escaping. When I twist or wiggle the switch the noise gets louder or quieter. Any hints on what I should be looking for once I remove the trim panel? Common failures? It's a 2005 HR Ambassador 36DD, Thanks
bgbassman(bluegrass bass man)
4 REPLIES 4
jorbill2or
The "switch" is actually a push pull "valve" with airlines and valving in and out behind the yellow knob. Its Not unusual to go bad and need repair or replacement. any truck shop can repair quickly as its a std part. Or you can get behind it yourself and see if a line going in or out is leaking or its the valve itself (replace) This is a Fix it before driving much part , it can leave you stranded on the road.
Bill
Jim
Shouldn't you expect to find a split air hose?
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
RedRollingRoadb
Likely that the valve has gone bad. Open the dash and confirm that it is leaking then pull it out and take it to truck dealer or someplace that deals in air brakes. It isn't an uncommon failure.
Mandalay_Parr
You will prodadiy have to remove the switch to investigate.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
