Air pressure
tennisgal33
The dash air pressure gauges on our 42' Meridian read 100. Is that what they should be and if not, can they be adjusted?
3 REPLIES 3
wolfe10
Yup, air pressure should NOT be steady, but should cycle between CUT-IN PSI and CUT-OUT PSI. When cut-in pressure is reached as air is used for suspension and brakes, the air governor "turns on" the engine-driven compressor until cut-out PSI is reached. The cycle starts over again.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Yaj
Our coach cuts out at 120psi and back in at about 90 to 100psi.
If yours is staying at 100 maybe your cut in/out are set to close together.
Upon start up pressure should build to about 120psi in a few minutes. Then you should hear a good release of air followed by a short slight hiss then it should stop until you use your air brakes or use air some other way (air ride adjustment, air horns, or a leak :E) as it goes down to your cut in pressure the governor should start it building pressure again. This is a continuous cycle. If yours stays running it may be hard on your compressor, I'm not sure about that though.
wolfe10
Your "AIR GOVERNOR" controls both CUT-IN and CUT-OUT PSI. They are adjustable. Check with your chassis maker for proper settings.
Brett Wolfe
Ex: 1997 Safari 35'
