ALladin tank monitor
Seabass69
My alladin system seams to be fine, except for the tank monitor. I replaced a sensor on the fresh water and it still shows XXXX for a reading on the tank and raw value on the sensor. I can only assume the monitor module is bad? it has power to the module. what are my options? I would like to get it all work as it should somehow. 2004 holiday rambler sceptor... thanks
5 REPLIES 5
Seabass69
dougrainer wrote:
Page 189 shows the calibration process. Doug
https://www.monacocoach.com/resources/media/manuals/2006_Signature.pdf
calibrating is the easy part after watching youtube. but its not registering any value on the sensors, even the new on. I did order a seperate system from seeland for now....
dougrainer
delete
dougrainer
dougrainer
Alladin system when you replace a sending unit you MUST input calculations for it to work. When NEW, Monaco had a calibration sheet in the owners packet that gave the values for your particular model. So, if no sheet, I don't know what you can do. You might try and contac these people. Doug
https://www.silverleafelectronics.com/node/4163
Ivylog
I believe there is a Sealand sensors conversation that works better.
Upgraded with a 08 HR Navigator 45’...
