โNov-04-2016 08:42 PM
โNov-06-2016 08:51 AM
โNov-06-2016 04:30 AM
Mlewin51 wrote:
After looking at the schematic I determined an inline fuse was in the system. We called the coach co and explained looking at the wiring diagram there should be an inline fuse somewhere. After back and forth talking to different folks we found the "mystery fuse." Sorry didn't know you wanted the whole story. I was hoping to see if anyone knew of these mystery fuses for awnings.
โNov-05-2016 08:11 PM
โNov-05-2016 06:07 PM
Mlewin51 wrote:
I helped a gentleman last week find a fuse. I looked over the wiring schematic and sure enough had to drill a 2 inch hole under the sink paneling to find an inline fuse. And modern rods have many fuses since modern amenities such as power windows, AC, even heated seats but everything is well documented and labeled to find inline fuses.
โNov-05-2016 01:11 PM
โNov-05-2016 08:38 AM
Mlewin51 wrote:
I have the first one without the extra roll down screen. I get no power at all to the control box. I tested the source wiring. Nothing nada. Checked all the fuses I can at least see. I come from the custom car/ hot rod world and its mind boggling that things would not be labeled correctly or at all, or at least provide a master list of ALL the fuses. I've heard about "drilling holes and behind secret panels you'll find a fuse."
โNov-05-2016 06:51 AM
โNov-05-2016 06:19 AM
Mandalay Parr wrote:
If the motor kicks in I doubt that it is bad.
Mine acts the same way when the wind sensor is wet or raining.
Ok after it dries out.
โNov-05-2016 06:10 AM
โNov-05-2016 06:01 AM
โNov-05-2016 05:56 AM
โNov-05-2016 04:43 AM
โNov-04-2016 10:21 PM
