Any regrets going from Gas to Diesel?
OldFogie
We have had a gas Class A and are looking at a Diesel.
Those of you have made the switch, did you have any regrets after you were in the DP?
Also, any feedback on a 2003 Fleetwood Discovery DP?
2007 Bounder 35E
2011 Jeep Grand Cherokee
1999 Jeep Wrangler
34 REPLIES 34
rgatijnet1
JimM68 wrote:
No regrets for us.
One thing on the Fleetwood, if it is important to you...
Many Fleetwood DP's did not have a raised rail chassis, and therefore do not have full passthrough storage.
You can tell if the basement doors come out with the slides = no pass through
Yes but many gas coaches, like my Monaco, do have large pass-thru storage so that is not something that is unique to DP's. If pass-thru storage is something you want, there are choices out there.
Valkyriebush
Valkyriebush wrote:
JimM68 wrote:
No regrets for us.
That's correct. No pass thru on mine, but the three large compartments that come out with the slide connect together for a very long single compartment if you need lengh and want to use it that way too. I bet the Discovery is the same.
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
Valkyriebush
JimM68 wrote:
No regrets for us.
That's correct. No pass thru on mine, but the three large comprtments that come out with the slide connect together for a very long single compartment if you need lengh and want to use it that way too. I bet the Discovery is the same.
2000 Jeep GC
2003 VTX 1800
ferndaleflyer
To answer the question-----NONE!
JimM68
No regrets for us.
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
w4phj
I waited way too long to transition into a DP.
Maintenance takes a bit longer as now I have about
4 times as many zerk fittings to grease.
2021 Winnebago View 24J
2021 Ram pick up
2015 Jeep Wrangler Unlimited Sahara
Ham Radio Extra Class Volunteer Examiner
FAA A&P License
1969 Plymouth Road Runner
chuckftboy
I went from diesel to gas and have no regrets so it can work both ways.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Koop
No regrets whatsoever. Went from a 37' Gulfstream Sunvoyager on a Workhorse W22 to a 40' Alpine Coach and haven't looked back once.
Mike
2003 Alpine Coach 40MDTS
400HP Cummins ISL
eheading
We definitely have no regrets. We bought our first diesel in 1992 and have had 4 diesel motorhomes since then. Last year we decided to downsize from our 41 footer. We looked at several gas Class A motorhomes, but we just couldn't go back to the gas class A and ended up purchasing a 34' diesel pusher.
Ed Headington
Valkyriebush
No regrets. Went from a 32 ft Pace arrow to my current coach. 03 must have been a good year as my Excursion has been a great RV. More cost but no regrets.
2000 Jeep GC
2003 VTX 1800
the_vfox
None at all.
Fox and Angel, fuzz ball cat and crazy Yorkie :S
Don't call me on the weekend, Im out camping.:C
2001 Itasca Horizon DP 36LD 330 Cat and all the bells and whistles
Go Blue, US Air Force(retired)25 years ๐Ÿ™‚
rivercity22
My only regret was I waited too long to get a diesel, test drive one and you will know why.
FOR SALE****2012 Georgetown 357QS*****
PM for details....
ugh
Most people ask if there are any regrets from downgrading from Diesel to Gas. Just saying...
2001 F250 5.4 3.73
2015 Wildwood X-Lite 262BHXL
Trackrig
No regrets with our 2005 Excursion 39S with a Cat C7 and Allison. I wanted a DP and took people's advice to buy enough MH the first time instead of upgrading several times.
Bill
rgatijnet1
No regrets going from gas to diesel, back to gas, back to diesel, and now back to gas again. Each one has it's advantages and disadvantages and when I find another floor plan I like, who knows what is going to be powering it. Personally I don't care what the power plant is because I have found that each of them has gotten me to the top of any of the Western mountain highways and back down again, pulling a toad..
