โJun-17-2017 10:30 AM
โNov-25-2018 06:50 PM
โNov-25-2018 06:49 PM
โNov-25-2018 06:45 PM
STBRetired wrote:fulltimin wrote:
Your exposure is greater than mine. Lol.
I know it's probably not perfect as a heating solution, especially in an rv, but I figure if I can button this turkey up enough, and cut down on the heat loss, that it might be a workable solution.
I watched a couple of guys converting buses into an rv, and they used the in floor heating technique, running pex. Definitely would be extra work, but the claim is, with the heat at the floor, keeping the floor warm, and then all the heat slowly drifting upwards, that it is a great way to heat a space.
Like I said, I haven't fully decided yet. I want to put some cork on the floor, and see how that feels underfoot, before making a decision.
Having 6 or 8 house batteries would be fantastic, but I am not sure I will be able to tolerate the weight increase, unless using lithium, and at this point, that's probably out of the budget.
Then again, things could change tomorrow, right? Lol. No, I am not going to win the lottery. I don't play, so I can't win.
Thanks for the info.
Was not trying to discourage you from looking at in floor heating. It is definitely way more comfortable than the forced air in my MH. I was just suggesting that you investigate the electrical demands from those systems. I can run my furnace overnight in 20F weather without running my 2 T-105s below 50% SOC. I don't know what difference the pump versus fan will make. And I think your MH will end up with better insulation than mine has.
One caveat that I learned putting in radiant floor heat in the bathroom. Make sure you absolutely know where all the tubing is run. It will be very important when it comes time to drill holes in the floor for plumbing and put in screws to secure cabinetry. Unlike the bathroom where you don't run heat under cabinets and fixtures, I think you will need to do that to keep things inside the cabinets from freezing when it gets really cold.
โNov-25-2018 06:43 PM
wildmanbaker wrote:
When I read the first 2 sentences of you "Black Friday" post, I though, man you are really about half a bubble out of plumb, LOL! Doing the floor first is a good decision. Hot water heat in the floor is kind of high end heating, as it is not the most efficient way to heat. If done correctly, it is also pretty expensive to install. Its also expensive to operate. A propane heater would be the most economical to operate, but would require an outside penetration for exhaust and combustion air. Once you get the subfloor down and the ceiling insulated, you will know where you may want to go from there. Remember, sizing for the average low, or high temperature may be a mistake. If you size for the absolute lowest and highest temperatures may be better, as you don't need to operate the units at max most of the time. Asking for advice is a good idea, but remember, its probably worth just what you have paid for it, LOL.
โNov-25-2018 06:40 PM
PastorCharlie wrote:
There are some interesting products on the market that block heat transfer and/or sound. I have seen some that are used on race car exhaust manifolds to stop heat transfer. I used one such product in my Jeep Wrangler under the floor cover and it does a little of both; blocking heat and noise. It is also impervious to water. May be something you can use for your build.
โNov-25-2018 01:57 PM
โNov-25-2018 01:44 PM
โNov-25-2018 12:59 PM
โNov-25-2018 06:10 AM
STBRetired wrote:
For in floor heating you are going to need something like an AquaHot system to heat and circulate the fluid. Most of them (or maybe all) use a glycol solution as the heating fluid instead of plain water so there is no concern about freezing until you get something like -50F. The only ones I have seen run on diesel fuel. I would think that there might possibly be some that run on propane. You can also get them with a domestic hot water loop which would eliminate the water heater. I have never looked to see how many amp-hours they use to run the pump and burner so I don't know how suited they are for boondocking. Granted, my exposure to them are through several friends with 40+ foot diesel pushers with 6 or 8 battery house banks.
โNov-25-2018 05:22 AM
โNov-24-2018 07:09 PM
โNov-24-2018 07:07 PM
โNov-24-2018 07:06 PM
โNov-23-2018 06:58 PM
โNov-22-2018 07:11 PM
