Jul-22-2014 07:53 AM
Jul-23-2014 03:11 PM
Empty Nest, Soon wrote:JayGee wrote:
A five mile hill at 60 mph takes 5 minutes,
at 30 mph it takes 10 minutes.
No worries.
Exactly!
Are gas motorhomes underpowered? How do you define “underpowered”? From a power-to-weight standpoint, any motorhome is not the ride you want for grudge night at the drag strip.
How fast do you want to climb that hill? How much extra fuel do you want to burn to go faster up that hill? Any modern motorhome will get you to the top. And traveling 30 or 35 instead of 55 or 65 up those hills will not cost you very much time by the end of the day.
But the more you mash down on that peddle on the right, the more fuel you will burn.
Life is full of choices. This is one more.
Wayne
Jul-23-2014 02:21 PM
No worries.
Jul-23-2014 11:36 AM
Mr.Mark wrote:
Rgatijnet1, our coach should be at the paint factory as the converter should have received it at the end of May. It takes a month to paint the exterior than back to the converter to made into a motorhome.
So, the rear end is already installed. The coach was driven from Canada as an empty shell with the four slides installed at the Prevost factory.
Whatever Prevost put in I'll just leave it as is as I wouldn't want to void the chassis or Volvo/Allison warranty's.
Learned a lot about Torque, RPM's and HP... thanks everybody.
MM.
Jul-23-2014 11:07 AM
Jul-23-2014 11:05 AM
valhalla360 wrote:That's a problem I have in the rain. I can't floor it at freeway speeds without spinning the tires in the wet.
Of course in terms of a MH climbing a mountain, if you run out of traction, you have other issues to worry about other than can you maintain 60mph.
Jul-23-2014 10:44 AM
rgatijnet1 wrote:valhalla360 wrote:Mr.Mark wrote:
Valhallo360, I had changed my post slightly before yours came up. The John Deere was digging itself into a whole while the steam engine tractor was pulling it. It was good video!
MM.
In that case traction was definetly the issue. Once the wheels start spinning, you aren't able to harness either the HP or the torque.
The rear wheels on those old steam tractors probably literally weigh a ton each, let alone everything else built out of heavy solid metal pieces.
A similar analogy would be to adapt the engine out of a big diesel pusher and put it into a smart car and put it up against a 1 ton pickup with the base gas engine. I can guarantee the pickup would hardly notice the smart car back there even though smart car would easily have more HP and torque.
I think that you will find is that with a steam engine, the power is in the pressure in the boiler, which is already built up to the maximum, before the drive train is put in to motion. It is not like a gasoline or diesel engine that has to develop RPM's before it can start delivering power. As soon as the steam pressure is released to the piston, all of the power is there, even at 1 RPM. The same goes for certain electric motors, which is why they are used in heavy locomotives. The diesel engine in a train powers the generator which powers the electric drive motor that makes the train move. The full power of the electric motor is there to apply to the drive wheels, right from a standing start. It, like the steam engine, does not have to develop any RPM's to have the power to get a huge train in motion.
Jul-23-2014 10:17 AM
No worries.
Jul-23-2014 10:06 AM
Jul-23-2014 09:11 AM
MM.
Jul-23-2014 08:02 AM
MM.
Jul-23-2014 07:29 AM
Mr.Mark wrote:
Rgatijnet1, yes, I understand what you are saying about the gear ratio. I've never seen it as an option on any coach, but I could be wrong.
I saw a video of a new John Deere (?) diesel farm tractor on a pull-off contest with an old steam engine farm tractor. The steam engine tractor pulled the four wheel drive John Deere with the JD going at full throttle while it dug itself into the ground with the big-treaded tires (they were attached back to back). The torque on the steam engine was unbeatable. The guy said the steam engine gear ratio had to be set for pulling OR speed.
MM.
Jul-23-2014 07:05 AM
Jul-23-2014 07:01 AM
Daveinet wrote:DanTheRVMan wrote:I'm not sure I agree with this statement, because it makes an assumption about RPM. All the torque in a world is nothing without RPM. Back in the day, I could leg press over 1000 lbs, but give me a bicycle pedals and hook me up to your drive shaft, and I'm not going to accelerate your 30K lbs motorhome. Leg pressing 1000 lbs was very slow, so I would be limited by RPM. Since the RPM is limited, there would be no RPM room for torque multiplication to increase the torque to the drive wheels.
How fast you accelerate to that max velocity up hill is a function of torque and weight.
Basically it comes down to the fact that one can not quantify any performance without both torque and RPM. Torque alone does not quantify the actual output. That is why the quantification of HP exists as it quantifies total output.
Jul-23-2014 06:41 AM
Mr.Mark wrote:rgatijnet1 wrote:Mr.Mark wrote:rgatijnet1 wrote:Mr.Mark wrote:the silverback wrote:
I designed engines for 35 years. It is about horsepower and weight of the Motorhome. NOT TORQUE!! Except the more torque means more horsepower. So if a gas MH has a good horsepower to weight ratio it will do just fine.
Mr. Silverback, I'm certainly not questioning your advice because you probably have forgotten more than I'll ever know about engines.
But, you are the first person I've seen that says 'not torque' is not a major component to power an engine. All the diesel converstaion I've read about engines is torque, torque, torque.
For instance, on the new motorhome that we have ordered, the engine has been replaced from a Detroit with 515 hp and 1,650 lb. ft. of torque to a Volvo 500 hp with 1,750 lb. ft. of torque. The Prevost guys say that I should be able to tell a difference on the increase ability to climb steep hills. That's what they are telling me if I understood them correctly.
MM.
Torque at the rear wheels, which is all that really matters, is a function of gearing, which is why a hand held 1" air ratchet can produce 2000+ foot pounds of torque in a truck shop. Plenty of torque with the air ratchet but it won't get you up a hill very fast. :B
Then you talked to a salesman and there is the old adage about if his mouth was moving he was lying.
Honestly, I don't know what that means about the air ratchet compared to a diesel engine. The info I got is from the Prevost sight where all the gear-heads hang out, they are not salesman but very intelligent folks (apparently, they have me fooled) LOL!
MM.
What it means is to ask about the gear ratio on the different rigs. Same engine and same amount of engine torque can climb hills much differently depending on the rear axle ratio. If one coach is geared for mountains and the other is geared for top speed, the engine can be the same and the one that is geared for the mountains will beat the other to the top every time. One axle ratio can give you much better mileage and another gear ratio can give you much better hill climbing ability, all with the same engine horsepower and torque. The axle ratio changes the amount of power that is available at the rear wheels.
I saw a video of a new John Deere (?) diesel farm tractor on a pull-off contest with an old steam engine farm tractor. The steam engine tractor pulled the four wheel drive John Deere with the JD going at full throttle (they were attached back to back). The torque on the steam engine was unbeatable. The guy said the steam engine gear ratio had to be set for pulling OR speed.
MM.
Jul-23-2014 06:30 AM
DanTheRVMan wrote:Mr.Mark wrote:d1725829 wrote:
My opinion, does it really matter how fast you get there as long as you get there ? I go for the thrill, I am in no hurry !
What my concern has been is that when we get stuck behind a very slow moving semi and we fall to their speed of 35 mph going up a steep hill, will I have enough 'umpth' to pass him without causing a major slow-down in the passing lane.
I'm not wanting to race anybody, I just want the ability to pass within reason instead of being stuck behind a very slow truck.
MM.
You should read http://prevostcommunity.com/PDF/Motor%20Home%20Fuel%20economy.pdf
max speed up hill is determined by weight/hp
torque is not a factor for steady state velocity up hill
GETTING to max velocity is determined by how fast you accelerate
For the same mass the more Torque the faster you will accelerate (F=MA)
So torque will get you to accelerate faster around a slow moving truck.
But the max velocity up hill is still only governed only by weight/hp as you are not accelerating so torque is not an issue.
I am sure you will love your new toy.
