Auxillary Battery Issue in '91 Fleetwood Montara
alaskantraveler
So I recently purchased a 1991 Fleetwood Montara. Its a base model that did not come with a generator. The coach batteries had been disconnected when I bought it. (not sure why). The batteries were bad, so I replaced them with new 12v batteries running parallel. Before now the coach lights only worked when the key was on which is obvious because the coach batteries were not hooked up. So I hooked up the coach batteries how I believe they should be hooked up in parallel. There were 3 ground wires. One very large one, one medium one, and one small one (I believe the sm. ground is for the LPG valve) all black wires. When we hooked it up the coach lights still did not work. So then we turned the key on. Immediately, the small ground wire from the chassis battery to the sidewall inside the engine compartment got hot and melted within seconds. So now I don't know what's wrong, first why didn't my coach lights work once I hooked up the coach batteries again? Second, there must be grounding issue why did the small ground wire on the chassis battery cook? Any ideas? I believe I hooked up everything right, but it was all taken apart when I got it so I will review that more.
5 REPLIES 5
alaskantraveler
OP here. The wiring is consistent with black neg/ red positive. There are not white wires. I will check with a volt meter to ensure. It is possible that as someone said before the a DIY replaced wires with the wrong color.
MrWizard
Moderator
Moderator
IF ? you have red and black at the battery
red is positive and black is NEG
IF ? you have black and white at the battery
black is positive and white is NEG
if you have ALL three colors, red black and white
you need to verify every single wire
in all cases where you don't know what has been done, you should verify ALL wires
I can explain it to you.
1997 F53 Bounder 36s
enblethen
Trace the wires.
Positive should go to circuit breaker or fuse
negative should go to ground
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Jim
A RV typically follows the convention of DC battery wiring having Red Positive and Black Negative. Then the AC wiring convention is White - Neutral, Black - Hot. There may be a couple white wires going to a ground in the battery compartment but that would be unusual. Usually the AC/DC system wiring is kept separate. You typically wouldn't find any Black AC wiring anywhere near the batteries unless a DIY'er was doing something in there with it.
For a RV as old as OPs, I'd suspect it follows the Blk-Red convention in the battery compartment. At least for the thick Pos/Neg cables. However, because he's not the first owner, anything could have happened as far as battery wiring goes. And what I think is that one of the positive wires (going to a battery positive post) might be black, and perhaps was wired to the chassis ground.
If the OP could take some pictures and post them here, we might be able to do a better job of helping.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
enblethen
Black is positive!
White wires are ground.
Trace out the large white wire, it should go to ground.
Bud
USAF Retired
Pace Arrow
