Avoided near disaster. Need help,
kaz442
DW heard a noise upon inspection my inner rear tire was chunking getting ready to blow. Need a place in Ohio on rt 80 near Youngstown where I can buy new tires.any help is appreciated.JKaz
1989 26' Jayco class C E350 460cu
5 REPLIES 5
Dragonfly
If you are still in need, there is a NTB at 224 and I-280. I know they can get them but call first to be sure they stock them. They would also be a good resource to refer you elsewhere if they can't help you. 7204 South Ave, Boardman, OH 44512
Phone: (330) 758-6966
DRAGONFLY - 2011, Provan Tiger CX, on a F350, 4WD, regular cab chassis
pconroy328
I see a couple of Walmarts too. Might not be the best tire you want, selection will be limited, but you can probably get moving again.
pconroy328
"On route 80" might limit your options. You're running a dually, could you SLOWLY limp to a Tire place in the morning?
I used Discount to put new tires on my Class C. But I don't see them in Ohio. I do see an NTB - they should be able to do it.
donn0128
Discount tire near Columbus?
dan-nickie
Let Me Goggle That For You
Dan and Nickie
2014 Forest River Berkshire 390RB
