Awning
kmiller
On the Road Warrior, has anyone ever adjusted the awning so it allows a tilt. To allow water not to build up in the center, I see the adjustment pins, but I was always been cautious not knowing if the awning would still work with the retract.
7 REPLIES 7
Peg_Leg
I always look at the lay of the land and try to determine which direction ground water will flow. Then I dip the corner that will "hopefully" allow for a flow away from entrance door.
Note: This does not always work as planned.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Mich_F
j-d wrote:
Mich,
Fully Extend or Fully Retract?
Whether he fully extends them, or fully retracts them, I was trying to tell him to make sure they were at the same position before retracting. ๐Ÿ˜‰
I just noticed in a later post that his awning has an auto retract feature. That will be an issue if it tries to retract with the arms at different positions.:E
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
kmiller
I was unable to find out the model in the owners manual, the awning is a Carefree of Colorado not sure if its a( Travel'r)? it has the auto retract feature with numbers and pins like the ones on a easy up shade tent. I did find the sn: 2088181862 and the Pn is OU183425.
It not the common type.
bukhrn
Yes, I put a slight angle on the awning for runoff purposes, but I always return both sides to the bottom position before retracting the awning, not sure it would retract properly otherwise.
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
j-d
Mich,
We've had what I'll call "the ordinary" A&E/Dometic and the Carefree of Colorado awnings. With both awnings, we've left one end "high" and the other end "low" but both ends were higher than the retracted/storage positions.
Then to stow the awning, I drop both arms all the way to the retracted/folding/storage/travel position. Advantage to that is that I can unlock the roller without using the rod. Then I hold the unlocked roller and walk to the center of the roller where I have the strap and rod ready to let it roll on up.
Mich_F
I would suggest lowering which ever side you want for rain run off, but fully extending both arms before retracting.
FrankShore
What make and model of awning do you have?
2014 F-250
2014 Minnie Winnie 2351DKS (Traded In-Burnout-Use A Surge Protector!)
2015 Arctic Fox 22G (Great Trailer But Heavy - Traded In)
2018 Lance 1685 w/ Solar & 4 Seasons Package
1999 Beneteau 461 Oceanis Yacht
En Norski i en Fransk bรฅt - Dette mรฅ jeg se!
