Hereโs the conundrum. If I rewire the camera,โฆeven if I manage to locate the other end of the cable and splice the wires, whatโs to prevent the little rodent #ยฅ<โฌ&$ from chewing it again? And, yes, Iโve tried every rodent cure out there; dryer sheets, all types of smelly oils, ditto for soaps, original D-Con (until the wonderful people at PETA had it outlawed), every (pretty much useless) D-Con substitute, bowls of anti-freeze, traps and pest repellent expanding foam to seal openings. Nothing has worked to date. So, now I have a disabled generator AND a dead rear view camera.
Might it not be better to install a wireless camera system? Yes, itโs another expense. But, maybe the reduced aggravation factor makes it worth it? Of course, that doesnโt solve the generator problem. Maybe a Bluetooth generator!?
