โJul-13-2022 08:04 AM
โJul-14-2022 06:13 AM
โJul-14-2022 03:47 AM
โJul-13-2022 06:27 PM
โJul-13-2022 03:09 PM
FLHTCI wrote:
I have a 2012 Winnebago Itasca. I bought all new Interstate battery in February, took the coach to Florida for 7 weeks without battery issues. All seven weeks we were plugged into shore power with the chassis batteries switched off, coach batteries on.
I dropped my RV off to have some work done on it in June, when I went to start the coach all batteries were dead including the chassis battery. I get home and plug the RV in assuming it will charge the batteries. Three weeks latter the batteries are dead.
My questions are as follows:
Shouldnโt the batteries be fully charged after being plugged into shore power for that length of time (3 weeks).
If when plugged in to shore power, when the RV is not in use, should I shut the coach battery off? If the coach batteries are off, with the batteries charge?
Thank you in advance.
โJul-13-2022 02:34 PM
โJul-13-2022 01:38 PM
FLHTCI wrote:
We had power issues in Florida. I can only assume that my inverter was damaged because it should have charged fully for three weeks
โJul-13-2022 12:13 PM
โJul-13-2022 11:39 AM
โJul-13-2022 10:51 AM
FLHTCI wrote:MountainAir05 wrote:
With a slight load on any battery without any charger on it will go dead in a few hours to days. Once its dead they usually do not charge back up.
Check the battery voltage on each battery using a volt meter. If each is below or near 2 volt DC they will not charge back. The new chargers will not charge a very low battery.
Have you check the liquid level on each cell and each cell voltage. If you do not know how to do that post back.
Will the batteries charge in they are shut off?
โJul-13-2022 09:39 AM
โJul-13-2022 09:17 AM
โJul-13-2022 08:11 AM
