Bedrooom slide mechanism on 2011 Coachmen Mirada 29DS?
susanka
We're considering a 2011 Coachmen Mirada 29DS. DH couldn't tell what kind of mechanism the bedroom slideout has. The dining room one appears to be a rack-and-pinion. We want to know because a salesman at a different place told us that pulley (cable) slideouts have problems because they don't always line up properly. Does anyone here have this information? I've searched the net for hours and can't find an answer. Thanks very much.
1 REPLY 1
dougrainer
There are no problems with the Accuslide Cable pulley systems. IF it has the Cable system, when the room is in or out, you will see the cables. Outside, you will see 4 cables. 2 in front and 2 in back. Same on the inside when retracted. IF they do not line up properly, it is a simple task to tighten the cables to pull in and out correctly. Doug
