Bedside Wall Lamps Not Working
Awigant
I have a 1994 Fleetwood Southwind Class A motor home. I bought it used, and the bedside wall lights have never worked. I have the proper bulbs in the fixture, but they still don't work. There is no switch on the wall lamps, however there is a small hole in each lamp. I think they are operated with the main bedroom switch. Can anyone help me resolve this problem??
4 REPLIES 4
RV_CONUS
Awigant wrote:
Thanks, I will remove the light and take a look. Thank you for your input!
Good Luck.
If the switches are in the assembly, and you discover they don't work. They are easily replaced. I picked up new switches at 2 different RV Stores.
They seem to be a fairly common item.
2006 Allegro Open Roads 34WA
2015 GMC Terrain
2009 Blue OX Aventa LX
2009 Brake Buddy Classic
Awigant
RV_CONUS
koda55 wrote:
I have never seen where the bedroom side lights worked with the over head light switch. I would think that the on/off switches for the lights are missing. That is why the holes are in the covers
Ditto.
Just replaced the switch in one of the lights. Picked up a backup switch for the other bedroom light which is starting to flicker when using the switch.
Take the lights off and see if the switch is for some reason inside the light assembly. If the outer switch nut came off the switch could easily be inside the light assembly.
Easy fix. Or Replace.
2015 GMC Terrain
koda55
