From the Bigfoot website troubleshooting section:
"If you have the "Front/Right" and "Rear/Left" lights flashing on your panel you must disconnect the interface cable at the panel or sensor for 10 seconds to clear the code. The interface cable has a 6-Pin connector at each end. It will be the smaller cable of the 2 that plug into the sensor and the only one plugging into the rear of the control panel."
The level sensor is usually mounted on the inside of the firewall.
Dutch
2001 GBM Landau 34' Class A
