โAug-11-2013 10:17 AM
โSep-30-2013 06:33 AM
Koop wrote:
Ray, I think this is actually a good idea. You want to have an adequate amount of water in your black tank to flush the paper and solid matter through when you open the valve,
I see you have a Gulfstream. My Gulfstream coach is plumbed so the bathroom sink drains into the black tank. I like this feature.
โSep-29-2013 06:09 PM
โSep-29-2013 09:13 AM
JCMSr wrote:
For those of you who are interested I have solved my tank sensor issues (at least for now) using a combination of the GEO method and rinsing with hot water as I previously posted. The combination of using the Dawn and Calgon plus filling the tank with hot water and letting it sit for 6-8 hours made an immediate difference. For the first time in over 2 years the tank monitor read Empty when dumped. The only problem I am having now is that it seems to go from "Empty" to "2/3" after only a few flushes. I think this is due to the location of the sensors on the exterior of the tank and will be relocating them shortly to see if this corrects this issue.
On note for those of you with similar model RV's. During this process I found out that the sink in the half bath was actually attached to the black tank rather than the grey. This makes filling the tank with hot water much easier. I still, however, will use the SaniFlush after each dump because of the spray action.
โSep-29-2013 08:28 AM
โSep-29-2013 08:26 AM
โAug-11-2013 08:44 PM
โAug-11-2013 07:20 PM
โAug-11-2013 07:14 PM
โAug-11-2013 06:38 PM
carp65 wrote:
We have been full-timing for 8 years. Black tank sensor is very finicky!
Sometimes it works, other times it still shows full even after dumping.
Grey water tank always shows empty after a dump. Not a real important issue
for us. All you have to do is lift the lid, and with a flashlight, look down
into the toilet and you can see how full it is. I usually can tell by the sound
of the water when being flushed.
โAug-11-2013 06:25 PM
โAug-11-2013 05:11 PM
โAug-11-2013 04:58 PM
โAug-11-2013 04:57 PM
โAug-11-2013 04:42 PM
nelson wrote:
JMO Wast of time and money. It is a black tank full of stuff, When it's full empty it.
