Aug-13-2017 10:17 AM
Sep-05-2017 01:00 PM
Aug-13-2017 07:43 PM
Aug-13-2017 05:42 PM
turbojimmy wrote:
I'm going to try to seal it with a Plasti-Mend kit.
If the repair doesn't work I'll drop it.
Aug-13-2017 04:51 PM
Aug-13-2017 02:51 PM
Aug-13-2017 02:12 PM
Aug-13-2017 01:47 PM
Aug-13-2017 12:52 PM
Aug-13-2017 12:17 PM
time2roll wrote:
Black is probably ABS. Poly is usually white.
ABS is same as black waste pipes used in homes and is bonded with a solvent that temporarily softens the surface of the plastic so the two surfaces can bond.
I recommend a sheet of thin ABS to cover the entire crack in one piece. If it goes around a curve you can form the sheet with a heat gun. Clean and sand the area per instructions and glue the patch on. Silicone can be an issue so do not short cut the cleaning and preparation of the area.
http://www.plasti-mend.com/cart/index.php?route=product/category&path=59
(also check amazon)
ABS sheet
Aug-13-2017 11:56 AM
Aug-13-2017 11:38 AM
time2roll wrote:
ABS? I have used and recommend Plasi-Mend.
Polypropylene? Probably needs welded by a pro.
Aug-13-2017 11:36 AM
MrWizard wrote:
i think you will need to empty the tank for the repair
the sooner the better
will probably need to let the tank dry
and clean out the crack, before attempting the repair
Aug-13-2017 11:33 AM
Aug-13-2017 11:21 AM
