I don't know if my problem was called the start fuse or not. I had a 2002 Bago. Brave with the 8.1 it kept blowing the 40 am fuse I believe that is the one. It would shut everything down. I was towed into a chevy dealer in Hagerstown MD the Tech found the shield on the starter was hitting cable at centain times and shorting out. Also had a problem once before that, was told the wiring harness was pulling to tight and caused the fuse to blow and shut everything down This is very dangerous the first time I was doing about 65 on I-81 at Bristol TN everything shut down everything was clear around me so no problem. The second time I was at a rest area and twisted the chassis a bit that is when it shorted out, had to be towed in. Hope this helps Roy
Roy B Coal Miners Son
USMC Ret
Semper Fi
