Charging question
MagillaGorilla
I have an 05 HR Admiral. Does the chassis battery charge when the gen set is on? I ask this because it is now in winter hibernation and I run the gen set once a month to keep everything charged. What I don't know is if I am only charging the house batteries or if I am charging everything.
Magilla
2005 Holiday Rambler Admiral 37' Gasser
16 REPLIES 16
kdk
No, the chassis batteries are not charged while on shore power on your unit, but you can purchase a upgraded circuit board that will do it. If I remember correctly the board cost around $85. The issue with this fix is that the boost relay was used as the connection to tie the house and chassis batteries together. It works but I didn't like the idea of having this (Trombetta) relay energized all the time as it gets quite warm and is right under my bed room. The real solution is to buy a "amp-l-start" from LSL Products (around $60), simple installation and problem solved. This has now worked good for me for 9 years; Blessings Keith
06 Holiday Rambler Ambassador
2016 Ford Explorer twin turbo
rgatijnet1
As far as I know, the generator ONLY powers your inverter/charge which actually does the battery charging of the house batteries only. To charge your chassis batteries, just run a separate portable battery charger from any 120 volt outlet.
Sam_Spade
toolttime wrote:
No they don't.That's why there is a booster switch in case they go dead
Please be a bit more specific.
What is "they" and exactly what don't they do ??
Quoting a little bit of the post that you are replying to would be REALLY helpful.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
toolttime
2015 Thor Tuscany 45AT
Sam_Spade
Bobbo wrote:
Every rig is wired differently. You will have to check yours to see.
And then do the same thing with the house batteries and the "truck" engine. Mine was supposed to charge in that direction.....but wasn't because of a bad relay (solenoid).
Bobbo
Every rig is wired differently. You will have to check yours to see. Before you plug in to shore power (or turn on the generator), use a DVM (multimeter/VOM) to check the voltage at the chassis battery. Now plug in shore power and re-check the voltage. If it goes up from 12.? to 13.? or 14.? it is being charged. If it stays 12.?, it is not being charged.
Bobbo and Lin
DSDP_Don
Let me restate what I said. In 2005, Monaco did not charge the chassis batteries from at least the Diplomat line on down, when the generator was running.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Macktee
My 04 Dynasty does charge all batteries when plugged in to shore power or when operating the genset. Macktee
04 Monaco Dynasty Diamond 1V ( Homer II)
2012 Ram 1500 4X4 Quad Cab towed
2013 Cargo Mate 28ft enclosed car hauler
2013 Hyundai Elantra GT
2010 Club Car Golf Car
DSDP_Don
"Magilla"......In 2005, at least with the their diesel pushers, Monaco did NOT charge the chassis battery(s) when the generator was running or when on shore power. They only charge when the engine is running.
You would need either the Trik-L-Start, Zantrex or Magnum system that attaches to both battery banks and charges the chassis battery(s) when plugged into shore power or the generator is running.
Don & Mary
xctraveler
Tiffin generator/shore power does NOT directly charge the chassis battery. Tiffin provides a trickle charger in the engine electric bay to maintain the engine battery when on shore power. Not real sure about on the generator.
I pull the fuse to the trickle charger when storing without shore power so that the electrics of the charger won't draw the battery down.
Paul
2012 Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
Tom_Barb
My Automatic transfer switch will provide power from either entry point (external or genet) to the same buss which provides power to the inverter /converter to the house systems and charge the house battery. When the house Battery is 1 volt above the chassis battery the intelic brain box will close the relay connecting the house battery bank to the two chassis batteries.
So Yes, mine will charge both battery sets. but not all coaches are wired the same, but your coach owners manual should tell you.
MountainAir05
Mine charges all battery if on Shore/engine/gen running. Some don't.
RoyB
Good use for a digital multimeter... It should read 12.6-7VDC across the battery terminals when it is just sitting there if fully charged. When you start up the generator then it should read 13.6 VDC (or more) across the battery terminal. This will tell you it is getting charge voltage...
Roy ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Sam_Spade
Most common setup:
With the "truck" engine running, ALL the batteries charge some.
With the gen or shore power, only the coach batteries charge.
A multi-meter is pretty much required equipment for an RV'er.
My monthly storage routine is to run the truck and gen each separately, each for 15 to 20 minutes to get them thoroughly hot. I run the A/C to provide a load to each one.....and to dehumidify things a bit.
