Chassis Wiring help needed
Driftwood1942
1995 Fleetwood Bounder 32' on Chev P30 chassis with 454 gas engine. Need electrical schematics for chassis, and diagrams for the in-dash fuse panel along with locations of emergency flasher and horn relays. GM says not available. Fleetwood says not available. Manual supplier wants $250 for the info. Please help.
3 REPLIES 3
jeffdpdx
I have a 1996 Fleetwood Flair, Fleetwood emailed me the RV wiring.
I can email you that if you think it will help. As far as the P32 Chassis manual, it is a two book set and you can find them online used for 20 to 30 bucks.
My books part number are GMT/96-P3-1 and -2 might want to search using 95.
I hope this helps.
Jeff D.
ca_HARTS
I have a P32 wiring I can email you.
Tom
Tom
enblethen
Welcome to RV.net!
I use a Chilton's manual 28642. It covers Chev. P chassis. It has the basic wiring diagrams and many other chassis information.
The flasher is located above the ignition switch above the steering column.
I believe the horn relay is in the same area.
Nice chatting with you!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
