Class A Elect.Help,Help,Help,
Latimer
Stoped at son`s,last night all things worked///
To day the slid outes,the jacks,and the dash air do not work.
I have checked every fuse I could find.
Need help can`t move.
Thanks
Harry Sawyer
9 REPLIES 9
Latimer
May have problem found no power thou 100 AMP Breaker
Harry Sawyer
Latimer
Yes
Harry Sawyer
A1B00902
did you put on you park brake first
Latimer
Check left side fuss box there is a hi amp 100 amp braker with a red
button pushed and lever come down at bottom. no power.
Thanks
Harry Sawyer
enblethen
Is there an electrical panel in the front left compartment? Have you checked for power on the main terminal there. It should be fed from a main fuse/circuit breaker near the engine electrical panel.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Latimer
It is a Gulf Stream on a Spartan chase
Harry Sawyer
Latimer
Iam pluged in to shore power.Eng, runs,
Checked and cleaned batter post.and rotated switch to off and back to on. no power???
Harry Sawyer
enblethen
What is the make and model of the chassis?
Normally the jacks and slides come straight off the batteries except the controls could come off battery control center. The dash air should come off the battery control center or the chassis fuse block.
I am guessing the rig starts.
Have you tried cycling the battery disconnect switch? Off then back to on.
Bud
USAF Retired
Pace Arrow
krivanj
Were you plugged in all night? If not, could the batteries be flat?
Fleetwood Revolution LE 38X
2011 Scion TC toad
