Hi,
There are reverse polarity fuses on many converters. They may have failed.
There are also fuses or circuit breakers between the converter and the battery bank. They may have failed.
If there is a main disconnect switch between the converter and the battery bank, that may have failed.
You may find it easiest to trouble shoot with a volt meter of some kind.
Regards, Don
