Thanks guys, this build is just let me say different. The trans started life as a 5 speed 1000 Allison trans. The people that did the build 52,000 miles ago. Put the Sun Coast 6th gear kit in the trans. So with that it does not allow me to downshift from 6th to 5th. I think for some reason this kit is making it go from 6th gear down to 4th. Thus skipping 5th gear. Going to get it back to Beans Diesel east OF Nashville Tn. And see if they can re-tune the trans. As the paper work shows they did the trans wiring and tune when it was Built.
If for some reason they can't get the trans do shift right. Will sell this one and put at 06 or above with factory tune 6 speed Allison 1000 in it. As the ones that are running that trans and a box made in South Ms.Along with the factory tune. Are finding it's working perfect. But that's $6000 more to get it working I hope.
Engine does not feel like its lugging even at 1400 RPM's and 45 MPH. Truck is pulling good. But as you know your building higher EGT's when doing that. I have driven over the road. For years and even back around 91 the Freightliner I was driving back then. It pulled its best at 1150 to 1200 RPM's. Everyone back then were talking about lugging the Detroit 60 series 12.7 but that is where it pulled best at.
Have had 3 guys that have worked on these engines of years, tell me its not hurting it at 1400. But I for one would sure feel better at around 1600.
Thanks guys for the info, and I have searched for the above info over the last 2 years or more. And its hard to find real world info. I found lots of info on the engines in Dodge trucks. But as you know lots of difference between our 275HP and there 230HP or so and less Torque.
Pete
2022 Ram Big Horn DRW
2016 Eagle Cap 1200
2012 Landmark Key Largo
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
