โNov-10-2013 03:33 PM
โNov-16-2013 06:12 AM
โNov-16-2013 05:47 AM
โNov-16-2013 04:13 AM
โNov-16-2013 03:53 AM
โNov-15-2013 08:48 PM
โNov-15-2013 02:53 PM
j-d wrote:
If your original tires were Load Range D, then you should not run more than 65PSI in your current Load Range E tires. So many inflate to the sidewall max, or 80PSI in Load Range E.
Just weigh your coach and inflate to the pressure indicated in the Load/Pressure charts available on the web. Doesn't have to be for your BRAND, just for a TIRE with the same specs as yours.
It's VERY common to replace "D" tires with "E" as they are much more common. I doubt the load range is the source of your rough ride. I believe it's
1. the fact it's a Class C "Cube Van" RV
2. more air pressure than your axle weights call for
โNov-15-2013 11:50 AM
โNov-14-2013 05:25 PM
โNov-14-2013 05:19 PM
โNov-11-2013 04:09 PM
โNov-11-2013 03:33 PM
โNov-10-2013 06:41 PM
โNov-10-2013 06:09 PM
โNov-10-2013 05:19 PM
