โSep-17-2018 05:03 PM
โSep-23-2018 12:11 PM
โSep-23-2018 09:37 AM
John S. wrote:
This is why I found my class c. I looked for an F550. That gives me 12,600 on the rear axle and 7000 on the front and I can tow up to 12k pounds too.
โSep-23-2018 07:27 AM
โSep-23-2018 06:49 AM
โSep-20-2018 06:17 PM
carringb wrote:ptbtx wrote:
The QVM Q18R5 link didn't work (at least for me).
Should be working now. Looks like I cropped part of the url. But they also revised the site, and i'm not sure if doc links are static urls still. Anyways... working at the moment.
All of the bulletins are located here BTW: https://fordbbas.com/bulletins
โSep-19-2018 05:20 AM
โSep-18-2018 09:06 PM
โSep-18-2018 08:25 PM
ptbtx wrote:
I've read that the front to back weight ratio should be 1 to 2, e.g. about 5k to 10k. What if I the weight is under capacity for each axle but the ratio is not approximately 1 to 2. If that's a problem I might end up with CC to spare but still end up having to move all my gear from back to front each morning. How far off from the ratio is acceptable?
โSep-18-2018 07:50 PM
โSep-18-2018 04:43 PM
camperdave wrote:
So is the v10 dead when the new 7.3 comes out?
โSep-18-2018 04:14 PM
ptbtx wrote:
I recently bought a 32' 2010 Winnebago Access (Ford E450 chassis). Prior to leaving for a 4 week trip and prior to loading it up for the trip I took it to a scale and the rear weighed in at about 9400 and the front at about 4000. So the MH itself is taking up so much of the rear GAWR (9500 max) that there isn't much left over for bedding, clothes, food, etc. I had to cut back on what I planned to bring and now have to store everything in the front.
So am now looking for advice regarding which models to look at with better OCCC especially CC on the back axle.
โSep-18-2018 01:58 PM
โSep-18-2018 01:55 PM
pnichols wrote:That's the promise, as a result of its lower operating RPMs. Plus almost certainly other contemporary tech such as high compressions ratio, variable valve timing etc. It replaces both the 6.2 and 6.8L, and promises better economy than the 6.2L as well.
To continue their E-Series ... maybe Ford engineers figured out how to get better gas mileage (or power versus physical size) out of a new 7.3L gas motor than they were getting out of their 2-Valve V10?
โSep-18-2018 01:10 PM
carringb wrote:
For had previously committed the E-series through 2020, but now leaked documents not only state major re-tooling for 2020 model E-series, but also it will be getting the new 7.3L gas motor. So, looks likely it'll be around for along time still. No reason to re-tool for something you're not going to keep going.
