โJan-27-2017 10:49 AM
โJan-28-2017 01:08 PM
โJan-28-2017 11:44 AM
Bud
USAF Retired
Pace Arrow
โJan-28-2017 11:37 AM
โJan-28-2017 08:24 AM
Bud
USAF Retired
Pace Arrow
โJan-28-2017 06:16 AM
mikestock wrote:
The point of the diode is to prevent the Honda from draining back to the house batteries in case there is a voltage differential in the wrong direction.
โJan-27-2017 07:23 PM
theoldwizard1 wrote:
Most "modern" vehicle charging systems are only putting out 13.2V-13.5V AT THE FRONT BATTERY. YOU ARE NEVER GOING TO GET ENOUGH VOLTAGE TO CHARGE YOUR HOUSE BATTERY !
โJan-27-2017 06:37 PM
ets1996 wrote:
I bought a kit I think Roadmaster Camping world or ebay can't remember which anyway it has a voltage reg and everthing needed to connect the toad to the motorhome. I wired it through the seven pin connector as my toad only uses 4 wires for the lights. It keeps the battery charged while using the supplemental brake.
โJan-27-2017 05:35 PM
wolfe10 wrote:
Amps is not the primary issue. Voltage drop, even if amps is rated way over actual could render the charge wire close to useless.
If voltage on the coach side of an isolator (wire run from batteries, fuse, etc is, say, 13.5 VDC and you loose .7 VDC across a diode-based isolator, you are NOT going to charge a toad battery with 12.8 VDC.
I agree, if you want/need it to be automatic, install a RELAY with an ignition-hot as the signal at the coach battery end. Fuse at coach chassis battery, fuse at toad battery and 8 gauge wire for hot and ground. DONE.
โJan-27-2017 02:41 PM
โJan-27-2017 02:25 PM
enblethen wrote:
A standard diode like this would work.
Diode
โJan-27-2017 01:42 PM
enblethen wrote:
Roadmaster diodes are rated at 30 amperes.
โJan-27-2017 01:29 PM
โJan-27-2017 01:19 PM
Bud
USAF Retired
Pace Arrow
โJan-27-2017 12:45 PM
wolfe10 wrote:
I see no reason for a diode-- that is unless you are dry camping and forget to unplug the charge wire.
And if you decide to use a diode, make sure it is not a standard one that "charges" around .7 VDC. That much of a drop will render the charge wire pretty well useless.
