Jul-11-2018 09:58 AM
Jul-12-2018 05:21 PM
Jul-12-2018 02:57 PM
fulltimin wrote:Lou29 wrote:fulltimin wrote:
Looks like someone may have bypassed the battery disconnect switch.
The solenoid is usually used to temporarily tie the house batteries to the chassis battery for help starting the vehicle. There should be a button on the dash, that when pushed, the solenoid engages, and your starter now has power from all 3 batteries.
If the blue cable comes from the chassis battery, the red cable tied to it probably goes to the engine starter.
On the left side of solenoid, that cable may run towards the rear of the coach which would go to the 12 volt system for the house current. It would go from there to the generator for an electric start on the genny, (if it has one).
The upper right corner is an isolator. One cable comes from the alternator, and the other two cables go to both the house batteries, and the coach battery. The isolator will charge both the coach battery and the house batteries while you drive. The isolator will keep the coach and house batteries separate when the engine is not running, so if you discharge your house batteries, it does not kill the starting (chassis) battery.
Also appears as though someone bypassed the fuse in the upper left corner.
Could you tell me what is the purpose of the disconnect switch, if I should hook it up, how it's supposed to be wired or should I just leave as is.
The disconnect switch is just that, and disconnects a battery from any load that is present when everything is turned off.
Depending on what one is looking to do, the wire from the starting battery could be wired in to the one side of the switch, the other side would go to the solenoid. What you would have is the blue wire to the one side of the switch, the other side of the switch to where the blue wire is connected to now.
Turning it off removes any drain from the chassis battery, and will prolong battery life, when the motor home sits idle for weeks or months at a time. Even a tiny drain will kill a battery in a few months time, when it's draining 24/7.
Also, there may or may not be a switch for the house batteries similar to this one. Same deal. It disconnects the house batteries from any draw or drain to prolong battery life.
Then when you are ready to go - flip the switch and everything comes back on.
Jul-11-2018 03:27 PM
Jul-11-2018 03:24 PM
Jul-11-2018 02:05 PM
MrWizard wrote:
(2) 6v are is 'SERIES' to equal 12v, or it doesn't work
and they will quickly be overcharged and boiled dry
grd-neg 6v pos - neg 6v pos + for house
the blue box is the shure power diode based battery isolator, charges both engine battery and house batteries from the alternator, while the engine is running
the solenoid is a battery cross connect temporary jumper for emergency starting
aka eng battery dead, house batteries good, push and hold button on dash for 30seconds, then while holding button twist key to start engine
aka built in jump start box
Jul-11-2018 02:03 PM
Jul-11-2018 01:19 PM
Jul-11-2018 10:42 AM
