โDec-13-2014 09:05 PM
โDec-29-2014 11:36 AM
โDec-15-2014 11:36 AM
rooney77 wrote:
I'm not looking to maintain the chassis battery. I want to be able to run the radio without fear of running down the chassis battery. Hence the need for the converter to charge the chassis battery as well as the house batteries. I probably should have stated that in the OP.
โDec-15-2014 10:05 AM
rooney77 wrote:
Is there anyway to tell definitively if when hooked to shore power my converter charges not only the house batteries but the van battery? I haven't found any documentation to tell me it does. I'd like the peace of mind of listening to the radio without worrying about starting the next day.
โDec-15-2014 09:28 AM
โDec-15-2014 09:21 AM
โDec-15-2014 09:17 AM
โDec-15-2014 07:01 AM
โDec-15-2014 06:55 AM
โDec-14-2014 06:00 PM
โDec-14-2014 01:27 PM
valhalla360 wrote:That's about all there is to it.
Before you plug in, take a multi-meter and check the voltage at the battery terminals.Plug in and check again. If it goes up, it is charging.
โDec-14-2014 01:24 PM
โDec-14-2014 09:52 AM
โDec-14-2014 06:59 AM
The only iffy part is if fully charged the converter may not put out any power and you won't see the voltage jump (turn on a few 12v lights and it should push the converter to come on)
โDec-14-2014 06:57 AM
eric1514 wrote:JaxDad wrote:
I think it would be easier to just put a little bit of folded paper under the end of the rocker switch for the Aux. Or Emergency Start switch. That closes the relay and connects the coach and house batteries together via the motorhomes existing internal wiring.
That's very clever and I'm going to look into it. If it works I could see wiring up a permanent on/off switch as a poor man's Trik-l-start.
