DEF
oldkeywest91
On an average how much DEF are people using per trip(or tank fill up) on late model DP.
8 REPLIES 8
xctraveler
I just put in 8.4 gal to top off my tank. I have driven 2500 miles since I put any in and at that point I was showing 3/4 full about 12 gal and I had 5 gal left in the tank. So maybe 6 gal of usage for 2500 miles (the numbers don't work exactly because this is all estimates), mostly open road miles, it does make a big difference. Stop and go will eat your DEF tank much faster.
Paul
2012 Phaeton 36QSH on Freightliner Chassis with a Cummins 380 pushing it. 2011 Cherry Red Jeep Wrangler Rubicon with US Gear Unified Tow Brake System. Check out my blog
FMCA 352081 SKP# 99526
lryrob9301
In a motorhome Cummins estimates a DEF usage rate of 2%. So, for every 100 gallons of fuel you would use 2 gallons of DEF. Assuming 8 mpg fuel mileage, that's 800 miles per tankful or 400 miles per gallon of DEF. At 2.79 per gallon for DEF that's .007 cents per mile.
Mike_and_Trish
I've used the truck stop DEF pumps once or twice, but even though my DEF fill is on the driver's side, it's so far back that I have to pull up partway after filling the diesel tank. So I mostly use the Blue DEF "boxes" from Wal-Mart, and generally add one (2-1/2 gallons) for each fill-up (usually around 90-100 gallons in my 150-gallon tank). That ratio seems to work out about right. I track my fuel use carefully, but haven't bothered to monitor my DEF usage any closer than this.
Mike and Trish
2014 Thor Tuscany 40RX
2016 Jeep Grand Cherokee on Blue Ox Aventa LX
Yorkiepoos - Janis and Jimi
algolfer
I have a 10 gallon DEF tank. I fill it about every 5th tank of diesel. So 10 gallons about every 400 - 500 gallons of fuel.
Mr_Mark1
We have a 16 gallon DEF tank along with a 230 gallon diesel tank. I tend to fill the DEF at every 4th fuel stop. The chassis manufacturer moved the DEF filler to the driver's side a couple of years ago. The fuel and DEF fillers are behind the same door about halfway down the side of the coach.
We have just over 12,000 miles on the coach now and I recall going about 2,500 miles on the DEF tank. I'll check my receipts when I get back to the coach (in storage).
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
ct1964ups
Never kept track...but I carry a 2.1 gallon can and every other diesel fill up I will fill the can and next campground will dump the DEF in...Chuck
2017 Newmar Mountain Aire Seville on a Freightliner/2015 Granite Grand Cherokee Limited
2012 American Tradition Merlot>>SOLD
Keep The Rubber On The Road
GO NOLES
xctraveler
I agree with luvlabs. We just dump in a couple of 2.5 gallon containers every so often unless I find an empty truck stop with DEF at the pump so I can go through backwards (my DEF tank is on passenger Side)
Paul
luvlabs
Depends on how long the trip is. Most diesels will use one gallon every 400-700 miles. Lots of miles when you have a 13 gallon tank.
2017 Winnebago Navion 24V
2014 Tiffin Phaeton 36GH (sold)
2012 Tiffin Allegro 32CA (traded)
2012 Honda Fit
