Oct-02-2016 07:38 PM
Oct-04-2016 04:25 PM
Oct-04-2016 03:00 PM
Oct-04-2016 07:12 AM
Blaster Man wrote:usersmanual wrote:Blaster Man wrote:
On my last two diesels, if I topped it off during the summer, both would expand enough to leak out the over flow tube. I could lay on my back underneath the coaches and see where it was coming out of the tubes.
why in the ell would there be a overflow tube on a fuel tank?
For the same reason there is an overflow tube in your radiator. When 150 gallons of fuel gets hot it expands...has to go some where.
Oct-04-2016 06:21 AM
Oct-04-2016 06:00 AM
Oct-04-2016 04:46 AM
Oct-03-2016 07:18 PM
Oct-03-2016 03:39 PM
Oct-03-2016 01:35 PM
Oct-03-2016 08:01 AM
steppinstone wrote:
what is the temp where you are? If you fill your tank to the max and sitting unlevel and it's very warm out the fuel will expand so most likely it's the vent.IMHO I would take it for a good ride and burn off a little fuel.
Oct-03-2016 08:00 AM
johnhicks wrote:
Thanks folks. So far I haven't been able to squiggle into position to see the top of the tank.
When I filled up air temp was about 88F and I did fill it right up to pump shutoff, so I too think it's probably expansion.
Oct-03-2016 07:12 AM
Oct-03-2016 04:21 AM
Oct-03-2016 02:53 AM
