The carryout, and carryout 2 both use the SW64 setting on the receivers and are compatible with each other. Using other single LNBA antennas may require you to go through the set-up each time you reapply power. As Triker mentioned, a Traveler or a free standing 3 LNA antenna will solve the problem. The Traveler is fast and easy, but expensive, and if you are in the trees, it will not work. The Free standing dish, requires some place to store it and setup each time you need it. Back in the early 2000s we used the roof mounted single LNA dish, and it worked fairly good, but in wind, it had enough slop to loose the signal. We got tired of that, and got a 3 LNA dish and tri-pod. Used a compass and the directions from the receiver to set the dish. Later got a Dish Aimer that attached to the dish with a periscope to see if you had a clear view of the sky, to get the signals. This worked great, even in heavy timber, to find a place to get all 3 sats. This worked great, but it needed someplace to store, and setup was time consuming. We progressed to a Carryout, what a difference. Just hookup and let it find the signals. This last year, we got a Carryout 2 and mounted on the roof in place of the old single LNA crank-up dish. We still use the carryout when we are in the trees. We looked at other auto dishes that were less money, but they were not compatible with the carryout we already had. It was obvious that to save setup time, we spent more money for the carryout 2.
Wildmanbaker
