DO I need REALLY GOOD house batteries if i NEVER boondock ?
hertfordnc
I am advising a friend who lives in his Mid 90's HR.
He's on a very tight budget and needs to replace the batteries.
He is always connected to shore power and occasionally runs the generator.
He thinks he needs to buy $500 worth of AGM golf cart batteries.
I'm thinking one cheap, marine deep cycle would be perfectly adequate. THe only issue would be longevity but in a typical year the battery may never go through a discharge cycle.
Is my logic sound?
Dave & Ellen Silva
Hertford, North Carolina
2002 Excursion
2007 Shamrock Hybrid
1972 Revcon
1976 GMC Birchaven (hot rod with plumbing)
Finding propane leaks with a match and towing in overdrive since 1987.
21 REPLIES 21
rlw999
One factor to think about is whether or not he ever wants to run the furnace without shorepower or running the generator.
While I don't boondock much, I've been in a few situations where I wanted some heat but didn't want to run the generator, I've got around 5 or 6 hours of safe furnace fan runtime in the batteries (continuous runtime), which should last at least for a typical night of intermittent generator use.
Though unless he has a high powered furnace fan, that wouldn't need $500 worth of batteries.
If he never needs to run the furnace, then a very small battery would be enough to run the lights when temporarily parked would be fine.
Lwiddis
"Is my logic sound?"
Yes.
CA_Traveler
BTW A Marine deep cycle battery is a compromised starting battery and not a deep cycle battery inspite of the label.
2014 Grand Cherokee Overland
Bob
CA_Traveler
The battery only needs to be good enough to start the gen. He could use a flooded battery with it's maintenance and shorter life normally but I'd recommend a AGM either 12V or 2x 6V which is more expensive but no maintenance.
Bob
bgum
U R correct.
dalenoel
If you don't boondock, we never do, is to have the charge in the house batteries to start the generator. Without the batteries being good enough the Onan will not start and stay running. Happened to me two years ago.
03 Monaco Neptune 36PBD DP - 18 Focus Toad
Wife, myself, and Oreo the Malshi
Blackdiamond
You are correct, just 1 12v deep cycle should last years
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC KTM
15' FE350s Husqvarna/KTM
07 Rhino, long travel, 4 seater
