โMar-30-2014 07:16 PM
โApr-05-2014 03:02 PM
dougrainer wrote:cpn dick wrote:
OK thanks guys I have changed the board to the Dinosaur from PPL. Now the controls all work , stays on ac, but the refer. doesn,t cool. been on for 24 hours, the a/c element is hot but no cooling. How do I test the thermister. Dinosaur says that if the thermister tests then I might need a thermister adjuster.
Thnaks for the tip on thr $89 deal.
Dick
You do NOT test the Thermister. You wire the 120 element DIRECT to 120 power for 24 hours. IF the refer does NOT get below 40 degrees and below 10 degrees in the freezer, your Cooling Unit is bad. Doug
โApr-04-2014 10:55 AM
Dick
โApr-04-2014 08:12 AM
โMar-31-2014 12:05 PM
cpn dick wrote:
I hope I'm replying to your suggestions in the right place. New to forums. Wanted to say I appreciate the thoughts. The circuit board is a very light beige, almost cream colored.As suggested by Doug. Should I get it bench tested or just replace it?
I will clean and tighten all the contacts and grounds before I do either. Thank you ,I will post the results when I have them.
Dick
โMar-31-2014 10:09 AM
Dick
โMar-31-2014 09:35 AM
โMar-31-2014 06:13 AM
โMar-31-2014 05:08 AM
โMar-30-2014 08:29 PM
