Electrical Issue
LaTriker
I have a new class c with 30 amp plug. I can plug into 30 amp with no problem. Can plug into 20 amp non GFI with no problem, but I trip every 20 amp GFI plug that I plug into. Do I have a problem that needs attention?
15 REPLIES 15
Flute_Man
Yes you have a grounding problem.
Open your power distribution panel and verify the white and the green wire on your main power cable are not connected together.
Get an electrician to help you if you need it.
Call me if you want.
Jerry Parr
602-321-8141
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
