Electrical
beetleman
Thanks for the help with water pump question. Now I have a new one. The porch light, compartment lights and one set of indoor lights do not come on. However, today for a short time the porch light turned on using switch. Now it does not work again. On the panel with the battery, porch and step switches, the battery light is on, and it wasn't on earlier. Any ideas on what is going on? The batteries on monitor panel says batteries are charging. We are hooked up to shore power.
2 REPLIES 2
chuckftboy
Seems you may have a ground issue. The ground wire is usually common to more than a single switch
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Lwiddis
IMO a stem to stern wiring check is needed....every connection, every wire.
