Evaporust actually works
femailyetti
I couldn't get to a sand blaster to clean some rusty parts. I was at Tractor Supply and saw this stuff.
I soaked the parts over night. this is what came out not a lick of rust. It wont remove paint, or some sort of gummy black junk that came off with a light scrubbing
If ya want a before shot, look at my restoring the Holiday RRambler post page 33
9 REPLIES 9
femailyetti
On a trail fit, The throttle works properly, and carb seems to clear every thing. Next up the vacuum lines.
femailyetti
I Had to notch the gasket to clear a bolt.
Jim
Passin Thru wrote:
That stuff is just Naval jelly AKA Phosphoric Acid.
If you paint Phosphoric Acid on a Cats ass it will pass a freight train.
HAH! Cracked me up.
The thing is guys, if you look at the bottle the OP shows in his post, it says it's not an acid, and has a neutral Ph. So...it's not Naval Jelly.
Jim@HiTek
Have shop, will travel!
Visit my travel & RV repair blog site. Subscribe for emailed updates.
Winnebago Journey, '02
Cat 330HP Diesel, 36.5', two slides.
down_home
Grand Ma and others used half vinegar and water and soaked metal in it, to gt rid of rust.
I've heard of this product and heard good things of it.
I have several old tools that need to have rust removed.
Ivylog
DutchmenSport wrote:
I've never tired it myself, but they say if you take a rusted item and soak it in Coca Cola over night, it will remove the rust. Lots of YouTube life hacks says this.
Thanks for your testimonial! I'll keep this one tucked away in my memory banks should the need arise.
It's the Phosphoric acid in Coke that does it and it's in all the various rust removal products. You can buy it at HD in the paint department by the gallon... usually green in color.
Upgraded with a 08 HR Navigator 45’...
rgatijnet1
And you can keep using it over and over until it turns a deep black color. Great stuff
gbopp
I've used vinegar as a rust remover, it did okay.
Thanks for the report on Evapo-rust. I'll try it next time.
crasster
Also Marvel Mystery oil totally removes rust. Thanks for the tip!
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
DutchmenSport
