Finding Out Generator Load Maximum
rookie_rv
Rookie Rver :C here! How do I find out how much (maximum) load I can put on (house) generator safely? Is there a technique or process to find out let's say running the air conditioner, two tv's, laptop, interior lights, etc....
(Generac 5500)
Darius....the "Rookie RVer"
U.S. Coast Guard Retired
"RVing....cause life's a trip"
10 REPLIES 10
Strabo
With ambient air temps say around 75, your Genny will run all electrical load in your rig. No problem.
04' F350 PSD TB SC FX4 XLT, TH-04' 32' Sandpiper Sport Fifthwheel WB Dual Axle
07' Rhino 686 SS106-ITP-AFE-BRP-T4-CDI-KIBBLEBWHITE-CVT-TSTICH-Ridgid LED LightBar-HID Conversion Kit-LIVEWIRE
04' Honda 250 Sportstrac quad
05' Honda 400 Ranchers quad
ArchHoagland
I've got a Onan 5500 and what I did was fire it up and turned on every electrical device in the coach except the furnace.
Sat like that about 15 minutes with no problems so now I know where I stand.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
2oldman
Mr.Mark wrote:
We have a 20,000 watt genny. .
Wow. That's a big one.
dougrainer
You have a Generac, but this manual is what every RV owner should have. The SPEC plate/sticker on your Generac should have the TOTAL amps provided.Doug
https://power.cummins.com/sites/default/files/literature/rv/F-1123-EN.pdf
Mr_Mark1
Good to know how to figure amps.
20,000 รท 120 = 166.67 ร— 80% = 133.33 amps. We could do pretty good with that.
In a compartment on the driver's side about 2 back, we have a 30 amp buddy plug for a guest if they need power too.
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
rk911
(Generac 5500)
determine the maximum wattage of the genny. once you know the wattage it's a simple math problem. AMPS = WATTS/VOLTS. so, if you have a 5500-watt genny then the maximum amp load would be 47.82-amps (assumes 115-volt system). some will argue that 110-volts is nominal, other 120-volts. for your purposes they're distinctions without a difference since the resulting math is essentially the same.
the other poster is correct in that 80% of load is about what you can expect without tripping breakers. some AC appliances will consume additional amps for a few seconds at startup before settling down into "cruise" mode.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
_________________________________
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'23 Jeep Wrangler JL
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
PeoriaKen
I have a control monitor in my RV. It is 50 amp and says when running Generator..
line one 30 amps Line 2 30 amps.. 40 amps total,, i went over once and it shut down one of my air conditioners..
Sandia_Man
A 5500 watt generator that outputs it's rated wattage will have little difficulty running the entire rig in your profile. Most RVs with a single AC come specked from the factory with a 4000 watt onboard genny, RVs with 2 AC units normally come with a 5500 watt version. Heck, even a high quality 3000 watt portable inverter genny outputting rated wattage will run the items you listed, at least that is what I've experienced.
As mentioned above, you have about 45 amps to utilize, which if coach has been properly wired should easily power a single AC unit, laptops, TVs, even a microwave oven at the same time. Most onboard generators with such low hours usually will require some TLC since they were severely under-used, our 9 year old Onan has nearly a thousand hours and purrs along powering our rig as if plugged into shore power.
Mandalay_Parr
5500 divided by 120 is about 45 amps.
I monitor mine using an ammeter.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
2oldman
I'd try to stay around 80% of max.
