flexvision tv password
ggrotz
i bought a 2002 chevy van conversion with a flexvision 12 volt tv.There is no manual for the tv.when i turn on the tv there is no picture.I pushed the menu botton and it says that i need to put in a password ,of which i do not know.Below password is v chip,which without the password i cannot do.Any help would be appreciated, thank you.
3 REPLIES 3
Executive45
It appears the previous owner password protected the TV for teens. "1111" is the default password. If that doesn't work, you'll have to reset the TV to factory specs which should override whatever password they put in. Then 1-1-1-1 should work. Good luck...Dennis
Corkey05
Take your pick -
Clicky
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
ndrorder
A quick google resulted in several links to Flex Vision User Manuals. If you have the model number, I'd expect you could google the user manual to see at least the default password. The default password in the one manual I looked at was '1111'.
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
