Ford E450 12v
tuscancouple
Hello from England,
We have a Ford E450 based RV in which I would like to fit a dash cam and ideally power it on when the RV engine is turned on/started up. Does anyone know how to pick up a switched 12v supply in the cab? That is reasonably easy to get to!
Many thanks
Mick
12 REPLIES 12
DrewE
tatest wrote:
Even if you do not have the upfitter switches installed, one of the electrical boxes (under bonnet) has sockets for the relays that would be controlled by those switches, which would let you install a relatively high current circuit that could be switched by one of the "hot when ignition is on" circuits.
I don't know the needs of your camera, whether the current demands are low enough to share a circuit with the switched line to the radio.
A dashcam is not a high power device by any stretch. It likely uses less power than a cell phone charger (while charging the phone) or an automotive GPS.
Harvey51
Our E350 has a 12 V power jack that goes on with engine start. I would just plug it in.
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
tuscancouple
Thanks for all of the suggestions. Radio seems a good place to start.
Some interesting points in the dash cam article, however they are becoming common over here and can be used in a court of law to support your case if needed. We have them fitted to our Harley's for the same reason.
Mick
tatest
Tom Test
Itasca Spirit 29B
Golden_HVAC
Hi,
On my motorhome, the dash opens up easy, and I can get to the radio controls very easy. I was able to find the switched 12 volt there. There is a not switched 12 volt as well, for the clock and radio memories.
I used the radio switched +12 to run a relay that connected my coach and engine battery together once the factory relay stopped working.
Good luck,
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
DrewE
Vulcan Rider wrote:
I'm guessing that NOTHING is going to be really easy to get to but the radio might be the easiest. Just be sure to get the power lead that is switched and not the one that's hot all the time for the clock and memory.
That is a good suggestion. Do be aware that sometimes the dash radios in RVs are wired to the house battery and not the chassis battery (and hence are not switched with the ignition), and sometimes even have a switch that allows for either setup. There should be the Ford factory wire for the radio power behind the dashboard somewhere regardless; that's the one you'd want to use.
aeejbe
Hello "From England"
Are the Rules of the Road different over there?
Vulcan_Rider
tuscancouple
ahh, I understand now. No there are none fitted in ours, it's a 2008 model. There is the fuse box on the drivers side and I was just trying to avoid going down there to find one! I'll see what turns up on the forum.
Thanks, Mick
rjstractor
Upfitter switches are extra switches and circuits in the cab for accessories, like extra lighting, etc. I don't think the E-series has them as an option like the F-series although I could be mistaken. My E450 was older, but there was a fuse block under the dash. I found a circuit that was hot only when the key was on and tapped into it for my backup camera transmitter.
2017 VW Golf Alltrack
2000 Ford F250 7.3
tuscancouple
What's an "upfitter switch"? Don't know that term
Mick
Farmerjon
Do you have the upfitter switches?
2015 F350 Lariat CC LB 4x4 DRW 6.7, 6sp auto, 3.73
2000 F350 lariat SC LB 4x4 DRW 7.3, 6sp manual 3.73
1987 F250 Lariat SC/LB 4x4 SRW 460 4sp stick 4.10
1995 Jeep wrangler
99 Star Craft 953
