Apr-14-2014 05:57 AM
May-14-2014 02:58 PM
May-08-2014 12:06 PM
tropical36 wrote:OhhWell wrote:tropical36 wrote:jolooote wrote:
Hi tropical36. This thing is the 'E'mergency brake. It is actuated when you push down the Emergency/Parking brake. It simply clamps an old fashioned drum brake in place. That name is misleading because the brake assembly won't do much if applied in an emergency braking situation. It is actually a Parking Brake designed to keep a parked rig from moving.
So, the same as a chevy chassis without auto park and most all have the brake ass'y on the drive shaft, regardless. My confusion was with these fluid leaks and how this fluid might be related to the actual workings of the brake itself. I mean yes, there can be tranny seal leaks in any of them that will find it's way into a drum brake system, but what does this have to do with the operation of it all? Also was confused with the E designation and no, there probably aren't many, real emergency brakes, disguised as a parking brake in the whole world and for any vehicle, unless one is moving pretty slow on the flats and geared down some.
The front end of the assembly has bearings. The ATF is there to lubricate and dissipate heat.
Alright then and just something a little extra that a Chevy/WH chassis doesn't have and even with the non-auto manual versions. Now this brake, surely isn't designed to be set while the rig is in motion, is it, cuz I don't really see a need for all this?
May-08-2014 11:56 AM
May-08-2014 07:42 AM
May-08-2014 06:57 AM
May-07-2014 06:27 PM
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
May-07-2014 11:25 AM
May-07-2014 11:01 AM
John&Joey wrote:Finally got around to checking the fluid. It was right to the bottom of the fill hole, right where I left it 2 years ago. I tried to squirt in a bit but it wouldn't take it. It was overfilled the first time I checked it but obviously it is not receiving new fluid now from the tranny.Pirate wrote:
And the point is?
First point is to determine if the unit does self fill, which when you see the layout of it I would doubt very much. Second point is simply showing the brake pad assemble and the fact that this is what more then likely destroys the unit. I would assume that some (and I do know of a few) will drive off with the e-brake on for a short distance. This more then likely destroys the ATF which in turns destroys the unit. I doubt very much that it leaks out of the unit.
Last point is the one that Fireup stated. Anything that is built can be unbuilt and rebuilt. There really isn't that many components in the e-brake and it really doesn't appear like a NASA design.
So did you ever check your unit to see if it was overfilled?
Apr-20-2014 03:51 PM
John&Joey wrote:No, but I will do it this week. Had to plant the garden today.Pirate wrote:
And the point is?
Apr-19-2014 05:24 PM
Pirate wrote:
And the point is?
Apr-19-2014 03:59 PM
John&Joey wrote:And the point is?
Fireup, Pirate, and RLS I just want to say this is the internet at it's very best. It really doesn't get any better then that.
Hopefully before this thread is dead, some true understanding will come out of it.
ON EDIT:
For those that need more of a visual to follow (like me):
Apr-18-2014 04:39 PM
Apr-18-2014 04:16 PM
indyzmike wrote:
Thanks FIREUP, since it is so difficult to locate the part numbers for the gasket, shoes, and seals, can you help us along with that info? It would save us a lot of time and trouble.
Apr-18-2014 04:06 PM
RLS7201 wrote:Why oh why would would Ford have us check the fluid in the z-brake if it has a auto-fill feature? I was told that it was on it's side when built and then filled. I think some old wives seem to think it will remain overfilled from the tranny. I will go out tomorrow and check my fluid. A couple of years ago it drained to the fill plug level when I checked it. If it comes pouring out again, I will admit my mistake and move on.
Drain your e-brake assy to the bottom of the hole. Come back 6 months later and you will find it over full again. Just the nature of the beast.
Richard
