Fuel hose
Fifty4F100
I just returned from my week in the Smokys. I need help with a problem I had as I was leaving.
As I was gassing the behemoth up, I noticed gasoline running under the coach. I had 2 rubber hoses that connected the line running from the side to the tank had cracked. I went to my local NAPA and Autozone only to find out I had to use radiator hoses to make the trip. Problem is they won't hold up more than a couple of years before they deteriorate. I am having a hard time finding 2" diameter fuel grade hose. One is about 6" long and the other is about 8".
Glenn in TN
2008 Ford F150 King Ranch
2012 Allegro Breeze BR32
2017 Mini Cooper (future toad)
5 REPLIES 5
B_s_Bunch
I know you undsrstand they will deteriorate but I would not leave them them long at all. as in a couple days while in contact with fuel. I made that mistake on an older tractor. The residue did a lot of damage in a very short time. Had to tear down motor. Carb, valves rings all covered in the rubber coating the hose left. Never do that again:o
Larry,Brenda,Travis,Jarred & MEME the Boston Terror:E TheBunch 2011 American Coach Revolution 42T:C The Double Wide
Daveinet
teddychamp wrote:
Napa has this Hose in stock.!!
X3 I just installed plastic tanks in my coach and bought hose from NAPA for the fill tube. Its expensive, 59 bucks for 2 feet.
IRV2
teddychamp
Fleetwood Bounder 39R 330hp Cummins Turbo Diesel
Freightliner Chasis
Ford Escape Limited - on ACME Towdolly
donkeydew
napa has in the bulk at the one near me. they seem to cater to trucks. i have also seen it available at truck stops
onebull
You will find it at a marine supply store such as West Marine.
