Fuel leak
Dennis37
While fueling I noticed fuel leaking under the left rear of the motorhome. The six inch flex hose on the fuel inlet had a split.
Might be something to check now and then.
3 REPLIES 3
prstlk
My Tradewinds, same thing. The fuel filler line pasted right behind the front wheel duh. When replaced the line I covered vulnerable portion of the line with aluminum sheet, held in place by heavy zip ties.
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
tropical36
Some years ago, I had this problem up near the filler neck in a hard to get place. After a few times smearing epoxy on it, I finally got it in the right spot. I also installed a piece of alum. over the generator's exhaust, which was right under the leak and even though, it only smoked a little, it looks really scary to see fuel dripping down on a hot muffler.
Haven't had a problem since, but do realize that these hoses don't last forever.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
Carvin_Marvin
I just replaced 4 of the 6 hoses on my 02 W22 Southwind. In addition, the seal ring in the filler cap had numerous cracks. I kept smelling gas fumes but could not determine the source.
