Fuse panel on 5500 Kodiak 2008 Chevy Class C Jayco Seneca
jtcpartners
My accessory plugs on the dash and the lighter on the center console are not working. I located the fuse panel in front of the passenger seat and removed the cover. THe diagram shows Accessory as #19. The 12v 20amp breaker/fuse in that slot appears to work because when I remove it the overhead light turns off. Put it back and the light comes back on. Is there somewhere else I need to look for the fuse for these accessory plugs? I use them for gps and phone charging. THANKS!
2 REPLIES 2
ronfisherman
Moderator
Moderator
Fuse 19 should be the correct fuse. 13 is for the trailer lights. My 5500 has circuit breaker instead of fuses. Maybe a wiring problem.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
Seneca_35GS
Your at the correct fuse panel in front of the pass. seat. Check fuse # 13. That is the fuse that covers the 12v outlets and the cig. lighter in the center console.
